Get Adobe Flash player
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: Timing Chain Tensioner
  1. #21
    Senior Member R. J.'s Avatar
    Join Date
    Jul 2012
    Posts
    5,527
    Member's Photo Albums
    Default Re: Timing Chain Tensioner
    Quote Originally Posted by WillyD View Post
    64k miles on mine...have bounced the tach to 12k several times...it still is pulling hard even then..
    My ZL 1 hits the REV limiter at 11,200 RPM
    THERE ARE FEW JOYS EQUAL TO THE FREE-SPIRITED THRILL AND EXPERIENCE OF RIDING AN ELIMINATOR MUSCLE CRUISER
  2. #22
    "King Of The 1/4mi (Internally Stock)" paulfun's Avatar
    Join Date
    Dec 2007
    USA PA, Pine Grove
    Posts
    3,937
    Yes my bike also hits the rev limiter before 12K.
    86 zl9
    85 zl9
    87 zl1
    87 zl1
    1700 thunderbird
  3. #23
    well when you have it wanked all the way and you are tryin to keep an eye on everything its real hard to decipher those tiny numbers and maybe with my bouncy tach its reading off but i know 8k is more of a launch rpm than an omg rpm....lol
  4. #24
    Join Date
    Jul 2012
    Posts
    5,527
    My tach also used to bounce & could no longer keep up with the bikes revs so I installed a Daytona meters digital tach. $135. Then later on I found a used ZL 600 tach on E-bay $55 that works perfect. The only difference is the face plate has the red at 11,000 RPM instead of 10,500 RPM. I wanted to change out the face plate but should leave well enough alone.
    Attached Images Attached Images
  5. #25
    I'm noticing some "extra" noise from what I suspect is the timing chain. I reset the OEM tensioner but its still there. Could (at 19k miles) it also be time for a new chain and guides along with a manual tensioner? If I need to open her up I figure I will bite the bullet and do the starter/alt tensioner too. What are your thoughts on the +4 deg adv? I'm stock with a K&N in the airbox.
    I remember someone posting to buy the parts for the Concours. Thanks.
  6. #26
    Quote Originally Posted by tomc585 View Post
    It is time to change it if it rattles. This is an unfortunate indicator of a bike that hasn't had the oil changed often enough. Cam chains are very sensitive to this! I bought a 750 turbo with approx 6500 miles on it with one! Others will recommend upgrading the tensioner. I have had good luck with the factory ones and have seen bikes with upwards of 100k running them so I don't see a need. Fortunately...it is more of an annoyance than anything else for a while. I have seen guys run rattling cam chains for tens of thousands of miles with no problems. That said...get to it when you can because you're an embarrassment to the rest of us!
  7. #27
    Quote Originally Posted by HilbillyRokstar View Post
    Since I've changed the oil every 2,000 miles since new I doubt this was a contributor but thanks for your input.
    Edit:I found a note I wrote to myself to use 2000 Concours ZG1000 parts, is that correct?
  8. #28
    There are exceptions to every rule....what oil did you use? 20/50 or synthetic will help keep it from happening again (10/40 is only good for cold weather use)...IMO if it's past the limits of the stock tensioner...it is technically worn out...I would therefore replace it regardless of what tensioner you run.
  9. #29
    Join Date
    Jul 2012
    Posts
    5,527
    ZL MARK has a thread for the 6 row link set up. They are the parts listed for the 2006 ZG 1000 Connie. He has all the part #s & @ prices for all the parts.
  10. #30
    1st few thousand I was using spectro which i believe was a semi, since then have always run a full synthetic.
Similar Threads
  1. ZL900 timing chain
    By torsten in forum Discussion
    Last Post: 11-03-2010, 08:57 PM
  2. Timing Chain Checkout
    By golddrakul in forum zl Talk
    Last Post: 06-01-2010, 11:50 PM
  3. timing chain
    By ghost in forum zl Talk
    Last Post: 01-18-2008, 10:09 AM
  4. Timing chain
    By Kris900zl in forum zl Talk
    Last Post: 07-01-2007, 01:04 PM
  5. Timing Chain Guides
    By JW in forum zl Talk
    Last Post: 06-02-2007, 07:45 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
