85 zl 900 with gas leaking from carbs any thoughts
Bump Nov 10, 2019
  1. Bump
    Bump Active Member
    85 zl 900 with gas leaking from one of the carbs. I put the petcock in the run position sometimes it stops. If i'm not careful it leaks down into my exhaust system and I get the gas ignites in my pipe. Whats going on?
    460
    :hello: One of 2 things or both. Your pet cock fuel valve needs rebuilt or one or more of the 4 float needle valves are bad or dirty.
  3. rkerg
    rkerg Senior Member
    1,689
    11
    Agree with RJ, also, you should check your oil to see if some gas has leaked down there.
