'85 ZL900 dies when shifting into first
bigdavet May 24, 2018
  1. bigdavet
    bigdavet New Member
    Yep, leave it to me to screw up a simple oil change. I accidently unscrewed the wrong bolt in the front, and now it dies when i shift into first gear. Neutral detente or something like that? Easy fix or hard?
    87kawzl Senior Member
    1,362
    86
    Check the safety switches on the clutch lever and kickstand
  3. WillyD
    WillyD Senior Member
    3,308
    86
    The clutch switch won't affect dying, only starting. The kickstand switch and the neutral switch will. I would check both of those. My guess is the kickstand switch.
  4. bigdavet
    bigdavet New Member
    Yes, like an idiot, I tried shifting into first with the kickstand down. It works fine...!
  5. prfixer
    1,348
    39
    Even with it down, it shouldn't kill the motor until you try and release the clutch also. Will it crank over in gear without the clutch being pulled in?(Be careful trying that!)
  6. ZLrider
    ZLrider Well-Known Member
    583
    14
    53
    Been there, done that. First ride of the year a couple years back. Felt like such a doofus once I figured it out.
  7. Wissler
    Wissler Well-Known Member Supporting Member
    776
    7
    Worse than that, my kickstand switch is currently faulty. So far I took off 3 times last week with it down.
  8. W_L
    W_L New Member
    14
    Good to know. I have experienced this issue couple of times this week. Now it makes perfect sense. I will need to inspect it.
