'85 ZL900 Oil Drain Plugs
bigdavet May 24, 2018
  1. bigdavet
    bigdavet New Member
    OK so I'm new to the world of Eliminators; I"m an old KZ guy myself. There are a LOT more nuts and bolts on these Eliminators...
    My question is about the oil drainage. In the book, there are two oil drain plugs mentioned. Of course, the photos in these manuals are ****. Besides the obvious one next to the filter, where is the second one? The old girl needs a fluid change, and I don't want to over-fill her. Thanks in advance!
    BTW this is a crazy fast bike. It's so incognito, nobody knows what it is, at least in this redneck town I live in hee hee
    bigdave
  2. prfixer
    1,348
    39
    The second one is towards the front of the motor and in yhe middle. It’s Exactly the same as the plug next to the filter.
  3. 87kawzl
    87kawzl Senior Member
    1,362
    86
    Use the oil sight when filling the oil. It will be over filled if you add the 3.7l stamped on the filler neck. They use a shallow pan on the Eliminator compared to the other models.
  4. markus56
    3,197
    And the level should be towards the top of the site glass......I go 1/4" from the top.
  5. bigdavet
    bigdavet New Member
    Thanks everyone. It was easy, and he really likes the new Rotella
