Hey guys,
I'm after what tyre pressures I should run in my tyres.
I've quizzed the local motorcycle shops, etc about it and I've hit a bit of a conundrum (that's a big word for this time of the day!!!). I feel, what I've been told, is a bit of rear tyre, sidewall flex, it's very apparent when I hook into any left or right corner, it feels like the rear wheel is in a slight power drift (...but it's not) and it's a bit unnerving sometimes, I've even given the bike to one of the guys to ride to see if I'm imagining it, and he can actually feel it too.
I've asked the local motorbike shops for their recommendations for tyre pressures and the answers vary greatly.
Some say, 36psi front / 38psi rear, other's say, 38psi front / 40psi rear, some other's say 38psi front / 42psi rear.
The Good Book recommends for the OEM tyres;
Front : Dunlop Tubeless F17, 100/90-56H @ 33psi
Rear : Dunlop Tubeless K425, 160/80-15 74H @ 40psi
I'm currently running;
Front : Michelin Commander, 100/90-18 56H @ 38psi
Rear : Michelin Commander, 150/90-15 74H @ 40psi
The max. recommended pressure written on the sidewall of both new tyres is 41 psi.
In the latest issue of "Motorcycle Cruiser" magazine, in the letters section, a person wrote in with a similar question and the guy replied that if you subtract 3psi from the maximum rated pressure (in my case 41psi), you'd be close to the tyre manufacturers recommended normal riding pressure, so using that information, my tyre pressures should be 38psi all round.
I've found even though the front and rear tyres responds well enough on the bitumen, it's like skating on ice on gravel roads (I travel about 3 kms of gravel / dirt from the bitumen to home) and I thought it would have something to do with the tyre pressures, personally, I think 38psi front / 40psi rear is a little on the hard side, but I'll get better tyre tread wear.
I'd really like your opinion on this and what pressures you put in your bikes and how your bike responds to your pressures.
Mick.
