AIRBOX PLZ!!! ZL600B AIR BOX CONNECTS TO CARBS
The full backstory on this was when we tried to start it a couple months ago after buying it the starter kept running and running and running until the battery died. Not sure what’s causing that or how to test for it.
12.7 at stand still doesn't really mean anything. check voltage when applying starter button and see if voltage drops.
Here’s what happened. After the start button was pushed, the starter motor started turning and would not stop until I would guess about a whole minute then the battery died. The Killswitch did not shut it off. The starter button was not stuck so I’m thinking this is a starter relay problem not a battery problem.
Still sounds like an alignment issue. Can you loosen the starter a little bit? If the bendix gear jams up tight the starter will do just what you are experiencing. I'm talking about a car, so take it with a grain of salt. Your 12.7 reading shows you don't have a dead cell. If it maintains that voltage for a few days that's a good sign as well. To really know how good a battery is though you need to load test it. I also like to check the cells with a hydrometer to see if they are coming up to proper levels and that they are all about the same.
I will look at the starter alignment next. Just need to figure out how to get at it.
Many thx for the continued support!
:hello: Bike starters operate differently than a car/truck starter. Bike starters don't move in and out they just spin. The starter clutch does what the bendex does in a cars starter.
R. J.,
What do you think causes the starter to keep running after the starter button is released? It only stopped when the battery died. The kill switch didn’t stop it and the start button is not stuck. Thx
I'm also curious about this. If the starter does not have a solenoid and bendix like a car, just how the heck does it work? Doesn't starter clutch = solenoid/bendix?
