BATTERY TERMINAL NUTS
MikeC Jul 7, 2018
  1. MikeC
    MikeC Senior Member
    452
    103
    Who the f designed them? Is Is just to frustrate me? Ok. Thanks for letting me vent.
  2. GaryD
    GaryD Active Member
    304
    17
    Yup...ground my teeth over them many-a-time.
  3. ZLrider
    ZLrider Well-Known Member
    583
    14
    53
    If you're referring to the nuts that attach to the actual battery, I got a trick for you. Cut a small rubbery piece of fuel line or similar and cram it in behind them. It holds them nicely in place.
  4. MikeC
    MikeC Senior Member
    452
    103
    I like it. I will do it TODAY.
  5. 87kawzl
    87kawzl Senior Member
    1,381
    90
    I always use a Phillips screwdriver on them and the threads usually find the hole with a bit of pressure. Once in a blue moon I use a flat blade between the battery case and nut to get it centered.
  6. MikeC
    MikeC Senior Member
    452
    103
    THAT'S what I mean, its like the screw is too short, or the nut too skinny and also, too small to center naturally. I like the hose tip for keeping the nut in there too. ALWAYS losing it.
  7. ZLrider
    583
    14
    53
    Have you guys considered longer bolts? Sounds like what I got is a bit longer. I never have any trouble starting them. The rubber tubing just keeps nuts positioned correctly and prevents dropping. Actually what I'm talking about is pretty much the same stuff your battery vent attaches too, not fuel line. If you wanted you could prob steal a couple 1/4" pieces off that overflow tube for this purpose. Turn it sideways and let the bolt bottom out into side of it, the bolt does not go through the middle......if that makes any sense, though I suppose it would work either way.
  8. VmaxRider
    VmaxRider Active Member
    171
    10
    Put a folded up piece of paper under the nut to hold it up until the bolt catches the threads.
  9. ZLrider
    583
    14
    53
    I suppose you could put anything handy under the nut, but something rubbery kinda grabs it and I just leave the rubber pieces in place. When I replace the battery I take out those little stubs and put them in the new battery.
