** Blow Gun for Carburetor Work **
SO CAL ZL
Well-Known Member
San Diego, CA
Thought I would pass this along.....This puppy will do a high-zoot boogey in clearing out any dislodged crud deep down inside those carb passages.
It works *****'n at getting down into any small nook or cranny on our carbs. Far superior to any conventional rubber-snouted blow gun. Thin pointed tip has 5 outlets directed forward and can handle up to 232 max psi air pressure throughout the unit; no leaks and it's comfortable to use. Swiss made and sold by Amflo (Schraeder-Brigdgeport). :winkcool:
SO CAL ZL
Nice, do you have a good source as far as price? Here is a link from a quick google search - $22. Later.
http://www.toolsource.com/variable-flow-star-blow-p-120021.html
Jarney...do that one if you can bulk it together with other stuff....great price!
I had to pay a minimum shipping and handling out of L.A. on mine as it was a single Special Order item (Not stocked locally) and it carried that cost burden.
You won't be sorry, it's perfect for close in hard-to-reach work. Judging by what's stated on that website, they state that 150 psi is max. Mine is stamped maximum 232 psi (16 bar) on the gun's body; I wonder if they've lowered the max air pressure capacity since I purchased mine? Dunno..?
SO CAL ZL
