Bringing a 79' XS11 Special back to life
87kawzl Aug 6, 2019
  1. 87kawzl
    311
    7200 mi bike with a 1980 parts bike. No key or battery, bought on hope and a prayer that it would run with some TLC. Found it for a good price and felt up to a small challenge. It seemed like a good idea at the time:roflmao::roflmao::roflmao:
    This thread will document my path in hopefully breathing some life back into the ol girl with some BS along the way. I know it's not an eliminator but I can't seem to find one of those on the cheap. Stick around if you like.
    Parts bike and project upon arrival.
    311
    Ordered a key from eBay, cyclekeysonline. $14 shipped to the house and will be here in a few days. Polished some paint and chrome in the meantime.
  3. 87kawzl
    311
    Front master cylinder was empty and full of crust. Time to go through the front brakes. Hoses and calipers will be cleaned up next as I wait for my key. I will use the eliminator battery to see if the motor turns over once the key shows up. Just putzing around cleaning and making a parts list for now. If she cranks over I will reward her with new parts!
  4. 87kawzl
    311
    Piston was stuck in there with what seemed like gorilla glue... $15 Harbor freight pliers barely made it with the pins fully extended. IMG_20190806_182137.jpg
    594
    :hello: Nice to see that someone else is documenting a bike project. :notworthy:. Looks like at least 35 years of sitting.
  6. 87kawzl
    311
    Thanks to cycle keys online I was able to open the crusty fuel tank and turn the ignition. What a mess...things ain't so pretty on the inside as they say. IMG_20190807_182137.jpg IMG_20190807_182137.jpg
    Like I was expecting a nice clean tank after what the master cylinder looked like! Here we go!
    594
  8. 87kawzl
    311
    I've got a 5 gallon bucket, at least I'm not going to have to deal with a flaking tank coating.
    594
    :hello: I never seen any tank coating hold past 5 years. Most likely you will have to use the EVAPORUST more than once. It took 3 times for my ZL 10 tank in order to get all the rust and it was not all that bad. You can buy a probing scope for your smart phone. They cost around $45.
  10. 87kawzl
    311
    I have a camera, thanks for the tip. I need some paint strainers for recycling the evaporust. Had to do my ZL tank twice because it flash rusted, coated it with marvel mystery oil after the second soak.
    Took off the front calipers and the pads are in good shape except the backings are a bit crusty. Crazy setup pivots on a single mounting bolts and the friction material is beveled, odd.
  11. 87kawzl
    311
    Front calipers will just be getting rubber, rear caliper needs a piston and rebuild kit. Rear master was in the same condition as the front, ugly. I rodded the front brake lines with the core wire from coaxle cable and now they are clear. Rear lines blew freely with air. Looking like ~$150 for brake parts. Some pics... IMG_20190811_112405.jpg IMG_20190811_122219.jpg IMG_20190811_140140.jpg
    594
    :hello: Inside the calipers looks to be pit free. Are you going to replace the seals and dust seals in the calipers. Did you ckeck the brake lines for dry rot.
  13. 2manybikes
    2manybikes Supporting Member
    54
    19
    The black one is an 81 Special and the red one is a 79 Special IMG_4029.JPG IMG_3175.JPG IMG_3388.JPG . With the discussion about Evaporust, I thought I would share a photo of my high tech tank dryer!
  14. 87kawzl
    311
    On eBay there is a set of all 5 brake rebuild kits for $108 (2 masters & 3 calipers). The piston will be ~$25 and all the hoses are clear and free from cracks. I tried the ZL battery and it came up short on CCA, the ZL size usually is around 230 and the XS specs out at 350. The ZL battery yielded just a click with each press of the starter button.
    2manybikes, you have some fine examples of the XS11, I've been looking hard at the current generation California for some longer range rides and I think we need to see some pics of that Kaw! Thanks for sharing the tank drier details.
  15. R. J.
    594
    :hello: Thats great that someone offers a complete rebuild kit for the XS 11. Who makes it and what Country is it made in.
  16. 87kawzl
    311
    K&L brand and the seller is out of FL. Pretty sure we know country of origin at that price. They just sell all 5 kits as a package.
    I've really got to watch the spending on this or if will quickly cost more than I will ever get out of it. I liked the idea of having an air cooled liter bike again and was hoping at 7200mi there wouldn't be too much cost in getting it going again.:roflmao:
    594
    :hello: I've only sold one bike for more than what I had in it. It was my first Moto-Cross bike which was a 1974 Yamaha YZ 125 mono-shocker. Which was the first singal shock bike on the market. I paid $600 for it. Put a new crank in it and first over piston. I sold it for $850 in 1976. I raced it for 3 years (74-76) at Ground Hog Valley Moto Cross Track in Punxsutawney PA. ________________________________________________________ IMG_7956.JPG IMG_7955.JPG
  18. 87kawzl
    311
    I pulled the plugs, tossed 10cc marvile mystery oil in each hole and let sit since yesterday. Pulled the plugs back out, put it in 5th and the engine turns freely. I oiled the cylinders just in case there was rust seizing the rings, I've heard of rings cracking after a long rest then restart.
    Time to pull the carbs and investigate what kind of mess I will need to deal with there.
  19. 87kawzl
    311
    Carbs with gasoline that turned back into crude oil, no kidding, it looked like molasses.
    Evaporust treatment for the tank
    That (or I) makes a mess of the floor.
    Some rust came out...lol
    And made a purchase that I will use on so many things...
    Rubber plug for 1 5/8 filler was $3, ultrasonic cleaner $80 with degreaser and 20% off coupon...in before additional tarriffs hit. Time to see if the cheap thing works.
  20. 2manybikes
    54
    19
    Did the carb kit you purchased include the fuel tee's between the carbs?
