Carb to air ducts - are they model and year specific to 1986 ZL600?
DesertKyorugi Jan 14, 2020
  1. DesertKyorugi
    DesertKyorugi New Member
    24
    Part number 14073-1211
    Is this part number the only one that would fit? It is a little too pricey for me at $20.62 each(x4). Do you guys know if there are other alternative part numbers that would work for less money? Thanks
  2. Trojan441
    671
    65
    As far as I know the part fits quite a few machines, but the prices are all similar. A Member posted mine from Japan around £67 including insurance n' postage that was to England!
  3. DesertKyorugi
    24
    :( I guess I will wait until I actually have to have them.....
  4. Trojan441
    671
    65
    There is quite a few posts about softening them up in boiling hot water n' using a good hot hairdrier whilst fitting them I have done this job 8 times but gave in n' bought a new set in the Summer some people mix Wintergreen oil in diluted alcohol or Xylene n' soak them for a few days! With old rubbers usually to put Air-box back in and align rubbers carburettors clips cables 2 hour job!
    https://www.kzrider.com/forum/3-carburetor/591124-xylene-wintergreen-solution-for-carb-rubbers
  5. Trojan441
    671
    65
    "Rubber Renue", but the active ingredients are 70% xylene and 30% oil of wintergreen,
  6. furchin
    2,143
    76
    90-91 Zepher 550, 85-96 Ninja 600, 90 Zepher 750 and of course the ZL 600.
  7. DesertKyorugi
    24
    I wonder if the ones from a KZ650/750 would fit
  8. Trojan441
    671
    65
    No, the last four digits are different! Screenshot at 2020-01-15 20:39:51.png
  9. DesertKyorugi
    24
  10. Trojan441
    671
    65
    Screenshot at 2020-01-15 20:58:34.png
  11. Trojan441
    671
    65
    Of course they are only, listing bikes officially imported into North America! Earlier Air-cooled stuff it seems will not fit, I think the ZR 400, the ZL 400 ZX 400 fit into this list. In Europe the KZ's were called Z's! The Japanese Home Market had probably more variants of the 400 n' whats fits the 400 fits the 600!
    Only other place to try is the "Grey" import boys! £67 or equivalent is probably the lowest price around!
  12. DesertKyorugi
    24
    The same eBay vendor lists the same part number for a Z400GP. Do these look remotely close enough to the ones for the ZL though?
    509
    :hello: If you are buying OEM I'd buy them now because you never know when they will be dicontinued.
  14. Trojan441
    671
    65
    That's what I was saying Japanese Home market had lots of 400 cc derivatives air-box boots are the same as the 600 cc ZL It appears the last machine to use them is the ZR-7 model till I think In Europe was perhaps in 2005.
  15. DesertKyorugi
    24
    Well, I volunteered to be the guinea pig for this one. I went ahead and ordered from Japan(Z400GP) for $34 a set of 4.
    I have plenty of time, my carbs are going out to Rick today and I am just starting to strip down the bike. My son will be back from the uni for the long weekend and we will get to work on the rest of the bike and taking parts from the parts bike. The gas tank recoat, frame rust and treating electricals should take up the whole long weekend :)
    We will get some saddle time too, the weather is supposed to be in the mid 70s IMG_20200108_145437.jpg
    Trojan441 likes this.
  16. Trojan441
    671
    65
    I don't know how far you have stripped it down but I do find putting wood under the side-stand to level the bike helps! Also the Air-box comes out easier I have found to the left the Cam-box cover also i have found wriggles out to the left, I therefore put both back in from the right, just my experience. With the Air-box I make sure all the wiring is out of the way n' gently tap it with a rubber mallet whilst in prayer.
    One inch of a bigger frame would have avoided all this juggling about!
  17. 87kawzl
    224
    You won't be disappointed with Rick's work.
  18. DesertKyorugi
    24
    Funny you mentioned that, I spent 4 hours yesterday getting the carbs out. The carb holders were stuck and all the clamps were rusted. 4 hours of colorful expressions and bruised knuckles because I want to avoid damaging any of the $$$ rubber and clamps. I hope the ZX600C is easier when I need to remove what I need
  19. DesertKyorugi
    24
    Yes, normally I would rebuild it myself but this one needs special touches and from what I have seen Rick is the man for the job
  20. Trojan441
    671
    65
    Actually the Air-box goes in from the Left too, its the Cam-box cover that goes in from the right I was getting them mixed up, but whatever you do make sure he bike is levelled up on a piece of wood!
