ARCHIVE_furchin
ZL600 Jet Kit and Pods (problems)
Put a K&N jet kit (made by Dynojet) on my little eliminator, the '87 600. It does not run as though it should. The history to date is that I installed the jet kit with a set up for stage 3. Circlip set on #4 with 2 washers on top and 136 main jets as instructions called for. I did not have the pod filters as they were backordered. Decided to run the bike some anyway. It accelerated fine through all gears. Problem was when cruising around 60 or 65 then hitting the throttle the accelleration was not there. It sputtered and spit around. If I down shifted and hit the gas it reacted fine through the rpm's. I figured this problem was because of no filters in place and was not too concerned 'till I got the filters. Well today the filters came and were installed. Now there is no accelleration at all in any gear to amount to anything. If I go slow to get up to speed it's fine. But don't ask to go fast quickly. So I called dynojet, they said to put circlips on groove #3. Did that and still have the same problem. Maybe a little better on the low end. I then figured to experiment by taking the pods off. Well guess what , all accelleration through the gears has returned. Although a little sputter while cruising and then asking for gas. Basically what I ask is does anyone have any theories on why bike runs better with pods off? I hopefully will be able to contact K&N tomorrow, the tech was gone for today when I called. Furchin
ANDY
