ARCHIVE_eliuk
coolent leak problem
hi all,
been having a problem with my 750
i've replaced the two small O rings that go to the cylinder and cured that leak, had look at the water pump and that seems in fair condition and the fins spin if i turn the engine over.
However i still have a leak behind the water pump, the oil ring behind the water pump looks knackered, does this O ring just seal the oil or does it seal water as well as i can't see where water would come from behind the water pump, i've checked the oil and it seems the water has NOT got into the oil. any pointers anyone please?
thanks
Keith
hi all,
thanks
Keith
I flushed mine just today made all the difference in the world. I would let out the clutch lever and it was like it didn't want to return all the way out. Flushed my brake fluid as well and now have better brakes. my brake and clutch fluid was almost a rust brown color.
