Disaster: The screw from Hell
Trojan441 Feb 2, 2020
  1. Trojan441
    770
    88
    Hi, rebuilt bike, put the carb's back in, rubber/neoprene air-box boots, air-box n' whilst undoing the central screw that holds the plastic surround guiding the cables, the Phillips screw flirted out n' dropped into cylinder 3 Spark plug access hole! At first it moved slightly, but then as I tried to retrieve it, it wedged itself against the Spark plug ceramic portion n' refuses to come out ! So I am literally SCREWED n' have no working bike, till I find a method to fish it out!
    Gutted like a Fish!
    Remover right-hand coolant hose for access n' then...
    Spayed with Double TT;
    Squirted oil down there;
    Used small screw driver, small pliers, wire coat-hanger e.t.c Not enough space for the magnetic telescopic thingy! In the end gave up for the day.
    244
    Strong magnet attached to a wire hanger or screwdriver or whatever will reach it. The magnet will magnetized tool of your choosing.
    Trojan441 likes this.
  3. Trojan441
    770
    88
    I will have a go 2morrow, nut access n' space is tight1
    547
    :hello: Did you try using one of those spring loaded 3 prong grappy tools.
  5. Trojan441
    770
    88
    No RJ, I didn't have one, Claw-Grabber. but have now ordered one on Ebay for future use! Not sure whether I could have got one in. I fiddled today n' bent an old springy metal coat-hanger into a small almost flatish fish hook shape. I had previously pump some oil down there and some Double TT spray, I then after some minutes managed to riddle it underneath and put all the force I could behind it . I thought at one point i was pulling so hard the bike would lift off the floor! Then it moved and I got some Snipe-nosed pliers had a go at retrieving it and it dropped back a little, Ho-hum, but a second attempt got it out n' I fell to my knees n' thanks the God's! Then I got the plug out wiped refitted it , flushed out the plug channel access started to refit the HT leads n' then it started to stop with rain commenced to heavier n' heavier rain n' i had t o cover the bike over n' retreat inside wet. but a relieved man. So 2morrow I should be back on the road. "Three shouts from the Top of a HIll" indeed! Incidentally the title Three Shouts.... is an Ancient Celtic Tale from Britain and found in Ireland too about the fate of a Celtic warrior and his two sons, when answering a challenge set by the God Lugh! A story which could be a minimum of 3,000 years old!
  6. 87kawzl
    244
    Attaboy Trojan!
    547
    :hello: When I work on a bike I cover the valve cover with a towel so no small parts/hardware goes into the spark plug wells.
  8. Trojan441
    770
    88
    Your a Wise Man RJ, however, I will make sure nothing like this ever happens again, also usually the HT leads are on blocking access, but an important lesson learned!
    547
    :hello: Not to wise. :laughing7:. I ones dropped a screw down inside a head on my old Dodge. I spent endless hours getting it out. :pain10:. I like your stories that you through into the mix of a thread.
  10. Klodos
    Klodos New Member
    Try to use pressurized air and blow it out.
  11. Trojan441
    770
    88
    Using old Suppressor caps to block off entrance to foreign objects! You can use an old towel as will I suppose as RJ suggested!
