ARCHIVE_gosupes
new member needs advice
First let me say that I am not new to ZL's. I bought an 85 900 in 1987 and rode for 2 years until I was force to part with it due to being young and out of money and have regretted it since. I recently bought another 85 900 and am in the process of rebuilding and repairing. It's in generally OK shape, mostly minor cosmetic issues. One issue that I do have is that it is hard to start and will stumble and die unless I just leave it alone for the first couple of minutes. Pulling the choke on seems to have little effect. I pulled the head cover off last week to adjust and inspect the valves. I found some vac hoses loose (between carbs 1&2 and 3&4) and a torn reed gasket between cylinders 3 & 4. Also cyl 3 running really rich, others look good. Once it gets warmed up it runs OK, but could probably be better. I figure I am going to have to pull the carbs out and have a look, but I am a little inexperienced at motorcycle carbs. I have been twisting wrenches on autos and aircraft for the best part of 20 years so I am fairly mechanically inclined. What are some probable causes or what should I look for? Also if I were to swap in another set of carbs, what makes good donors? Is it as simple as finding another set of similar sized carbs, or is there more to it? Sorry for dragging on. Any links to reading material or articles would be appreciated.
