  1. Jason Terry
    Jason Terry New Member
    22
    The fork seals on my ZL 900 have been leaking for several months now. Now i have noticed at slower speeds
    my front end has a slight bounce. I thought i had a flat spot in my front tire so i purchased a new one. The bounce is still there, could this be because of low fork seal oil?
  2. markus56
    3,462
    221
    What are you waiting on......rebuild those forks! You won't get many jobs on these bikes easier than rebuilding forks.
  3. 87kawzl
    353
    Could be a tire balance issue, rim out of round, wheel bearings or warped rotors if it's a constant bounce.
    low fork oil will make the forks more springy since the oil dampens the movement. It will allow the suspension to bounce a couple of times instead of compressing and going to it's normal position if you hit a hole or bump.
    630
    :hello: I 2nd on the fork rebuild. While the front wheel is off check the wheel bearings for wear.
  5. bobst2
    bobst2 Senior Member
    129
    103
    there leaking anyway need repair will contaminate your brakes and and yes will give a strange feel.
    if you go to my pictures will show you a way to rig up a ladder to support the bike. BUT BE VERY CAREFUL
