I buggered up 2 of my bearings in the bevel case and have to replace them.
Part numbers are: 92116 and 92116A on the parts diagram. I had to impact the bolt (part# 92001) off to get the bearings out and neeed to know if this bolt has to be impacted back on or is there a tourqe spec on this?
The problem came up when I had the case sand blasted and the guys doing it busted the seal I had put on it and the blasting material got inside the bearings. When I tried to clean up the mess inside the gears would not move at all so I had to take it apart.
The bearings and all seals on this were cheap so not a worry that way but does the bolt impact on or not?
Thanks for any help you can supply.
Cheers,
SD
