Yep, all good replies fellas. KK, not at all mate, you could call me a dinosaur too, I do ride an ‘80s retro which is out of step with the temporary citizens on their crouch rockets today. Yes, I like the idea of keeping it original and I’m more than happy with the performance of the OEM setup (carbs/ignition). The only reason I am considering EFI is I’m interested in the economy gains and whether I could actually do the installation. It was always going to be false economics because the improvement in fuel consumption could never compensate the cost of installing the system, even a cheap used BMW setup. Cold starts are never a problem for me; choke on, idle for 1.5mins, choke off and its smooth as silk. I’m also very happy with its current reliability and I’m comfortable taking it anywhere on long 6.5hr trips without tools, knowing the thing back to front and inside out helps my confidence. Because I do all the maintenance myself, I know what has and hasn’t been done and the minute details and condition of all the parts I work on.
One of the main reasons for considering this project is the (minor) risk of bending another conrod. On the shed floor I have the original motor that the previous owner wrecked when he let the carburettor needles and fuel petcock deteriorate to the point when fuel drained into the inlet and she hydraulically locked during starting and this bent the rod. This doesn’t happen with EFI systems. Another point is that I always intended to make the installation entirely reversible without leaving a trace behind (hence the external fuel pump and maintaining the same 34mm throttle bodies etc).
Of course the final decision to proceed will not be made until I know all the risks, costs and schedule (I can’t do without my daily ride).
TBusaMike, why would I need to
index and machine the intake camshaft for a reluctor and machine a place in the valve cover to hold a camshaft position sensor
The cam shaft rotates at exactly ½ the speed of the crankshaft so I don’t see the need for more than a crank sensor which the bike already has. I assume this is purely for the signal pulse for the injectors and surely a simple solid state module on the crank sensor ignoring every other pulse should accommodate this.
Monkeyhanger, the Z1000 has 38mm throttle bodies, too big to fit the inlet tubes and I don’t want to loose the bottom end torque with the bigger throat of the larger throttle bodies. The boost to the top end, while beneficial, would be unnecessary (this top end boost would also negate the improvement in the fuel economy, you know, if its available, I’d certainly be tempted to use it).
Hey guys, thanks for the feedback, keep it coming, its all good food for thought and very encouraging. You see I’m sure we’re doing all the development work for the KHI engineers as they consider the release of the ZL1200 fuel injected, upside down forked model in 2009. They can read english and they are looking over your shoulder…
