Grommets for stick coils
prfixer Oct 12, 2019
  1. prfixer
    1,534
    80
    Found these by accident doing a tuneup on my wife’s Acura RDX. They fit like a glove.
    Fern, markus56 and R. J. like this.
  2. GaryD
    GaryD Supporting Member
    443
    43
    Great find...I need these!
    We don't have Acura over the pond. Is this the 'posh' brand of Honda?...and if so do you know if there is an equivalent in their range.
  3. GaryD
    443
    43
    looks like I have found the answer...
    GS33533 Spark Plug Tube Seal Honda 2.4L DOHC VTECH K24A2
    I think the UK part No is 12343-PCX-004
  4. wuputt
    3,182
    47
    Now THAT is some valuable info! Thank You
  5. prfixer
    1,534
    80
    R. J. and markus56 like this.
    626
    :hello: I was thinking about going to stick coils. Great find. :notworthy:. Thanks. :notworthy:. I saved that E-bay seller to my watch list.
  7. prfixer
    1,534
    80
    They fit well, but they still won't seal a carwash(I know you don't have to ask how I just found out)!
  8. 87kawzl
    352
    Some dielectric grease should help seal it up against some normal rainfall. Pressure washer, maybe not so much but worth a try.
    Maybe silicone around the inside grommet to plug end and grease the OD of the grommet with the dielectric.
    626
  10. Ed
    342
    70
  11. prfixer
    1,534
    80
    Is it rated to stand up to the heat of the head? I couldn't find a temp rating shown.
  12. Ed
    342
    70
  13. 87kawzl
    352
    Permatex shows -65 to 400°f range and recommends it for plug boots. It will probably help with moisture vs a dry connection.
  14. Ed
    342
    70
    All dielectric specific greases are about the same low viscosity and they're sometimes used directly on the contacts. The DC111 is too thick and won't allow good metal to metal contact but it's great for gap filling as well as being resistant to heat and pressure. If you don't need those qualities, any good silicone grease should be able to take heat.
  15. prfixer
    1,534
    80
    Just ordered a tube of the 111, thanks for the tip and info!
