Hallo =)
Wold
Russian Federation Wladiwostok
Greetings for You! =) all together =)
i have ZL900 85 year
its great =)
just a little look forums
cool!
what is Engine icE?
its first question
i have a million of them %) but hard collect mind in one fist %)
and how put here a pic?
Welcome to the site Wold.
From what I understand, Engine Ice is an additive that you put into the coolant to help the engine run cooler and not overheat.
my zl warm up so hard, in traffic trombs when i cant drive between the cars i feel hot from engine
i wash radiator and make all waves on it right
but not big changes
i put colder sparkplugs (ngk dr9XX) and cant see difference
on ngk dr8 was little red ash, on dr9 no dust or ash just end of sparkplug white and aroung black
some times fan begin work ( thats oil temp is 110 ?)
i use castrol nf antifreeze, i think it good
and 2 days ago i tested relay (charge accum) and saw that oil begin foam!!!!
and i think now it was break pomp seals or head padding (seal) or HEAD BROKEN???! and antifreeze going to ooil
I dont think this is unusual Wold. On my ZL I have the same, especially when the fan comes on, there is a lot of heat comes up from the engine... not bad in summer... VERY nice in Winter....!!!
What makes you think yours is too hot? Do you hear bubbling in your engine after you turn it off? Is there steam rising from under the fuel tank? Do you hear your fan turn on and off while in traffic?
Welcome to ZL-oa Wold, I think you are the first to join us from that corner of the world!
Looking forward to seeing your photos.
blag
G'day Wold from Australia, ...gee we are getting very international aren't we guys, now a member from the Russian Federation, this has gotta be a first.
Wold,
It sounds, by the symptoms you've described, like one of two things, either you've got a blown head gasket, between one of the coolant and oil galleys, or a cracked head. If you have coolant/anti-freeze in your oil and it's starting to emulsify/foam the oil, that usually is the most likely cause.
The plug colour also sounds like the air-fuel mixture is way too lean, which would make the bike run too hot and it's highly likely that it caused the cracked head or blown head gasket.
I might be wrong, as it's just an educated guess?
Mick.
may be 3 or 4 times i heard bubbling in engine, way to garage is very bad and must drive on 1 gear some minutes
i think it boil coolant
no steam and some times on and off fan in traffic
if you can say its ussual situation - thats ok
ye, i begin think that problem is gasket or head
i hope it s gasket, because they are in bad condition
i think it was hot not in air-fuel mixturreasone
ok,think tommorow will have time to look what it have in head :blackeye:
Foamy oil is NOT usual and you should check the oil level as if it is high, you might be getting water into the oil.
Over heating and oily foam would make one think you have a blown head gasket.
Just foamy oil could be a water pump leak.
Are all the plugs the same color?
my photos =)
here i think buy or not to buy .. ZL400 SE (just without cowl)
here my first crashtest =)
2 month wait fork from Japan
here summer and sand, "Far Eastern International Moto Travellers meeting" 2005
here my extrim february run on asphalt, snow and ice about 400 km
here i'm and ZL900, my birthday =)
i sad usual about hot engine, foam i see only one time
oil level is not to high
and i think what first to do, disassembly pump or head
all plugs the same color
one man advise me take off oil and stay for some time and oil and water will go different levels, but nobody sad how recognize problem in pump or gasket (head)
Hi Wold.
SD & Stormy are right, I missed the bit in your earlier post where you said you had foam in your oil. This is not good.
How old is the oil in your engine? If the oil is old then you might have a slight brown colour to it when you look into the viewing port on the side of the engine, you can see tiny little brown bubbles. You will not get this with good new oil. If there is water in your oil, you will see it, coolant turns oil a colour off white, almost like a weak chocolate milkshake.
Warm your engine and change the oil, Maybe even after draining out the old oil, flush the engine with cheap oil, drain that off and then fill with your preferred oil. Check it again with new oil in there. If you still have foam its a sure sign of an internal internal leak and hopefully it is only a gasket.
Nice pics by the way.
Wheelie bars...
Even though it appears to be attached to a Hardley Worthitson here, so I assume it's fitted here purely for pushing the bike when it breaks down...lol
steering damper...
oil, i can say, fresh, work about 400-600 miles, i offen look at side window
i use only Lique Moly 10W40 - good oil
and never saw foam before - its water and not so far
oil now not white and chocolate, when it going to foam - yes, but bubbles of foam always brighter, i know =)
Welcome Wold, so glad that we now have member in Russia!
Engine Ice actually replaces your antifreeze/water. It is pre-mixed and expensive. Sounds like the oil issue needs first priority!
I need to do some research on this, see if it is possible that the seals are both gone in the waterpump, causing water in crankcase. If the seal is bad you should be leaking oil/water just by the left side footpeg.
Wold welcome from the ststes. Got any more pics of the bike? I'm curious about differences in the models
