headlight indicator removal solved
  • Thread starter Thread starter ARCHIVE_SnakeDoctor
ARCHIVE_SnakeDoctor
Need long distant calls for FREE
I don't want to break any rules here, so if this is wrong, delete it and tell me. EVERYONE Can make calls to annyone else on a computer by using a FREE download from www.skype.com You can call anyone anywghere in the world from computer to computer using this download and can even call landline numbers at a very discounted rate. I only use the free pute to pute method but everyone I know has a computer so no problem. I didn't know if you guys knew about this but it's fantastic. HOpe I can help yuou guys save some money calling friends and family. I do not make any money off this at all so I shouldn;'t get in trouble with the forum, but let me know ior when you get it you can contact me with my username on Skype and it is: Eliminator900
Cheers
Hey,
he's right, the two of us and another mate of mine in Queensland have used skype several times and I've only got dial-up (50.6Kbps usually) and it works OK at these slow speeds (only a slight delay, broadband would be even better).
Hey bro's and gal's - repalced my busted headlight shell with one that needed a replacement indicator lens - easy fix - the lens'' just pop out then pop back in - line the slots up and wallahh - I didn't need the chrome ring replaced but I had heard others did so I tackled that problem last night - with success - here's how I did it:
First - DON'T use pliers or channel locks
That being said - I used a very fine edged wood chisel (retired carpenter I use the tools I am familiar with) and gently with not much force put the edge under the chrome (actually plastic) edge and gently pried going around it twice and it popped off intact - if anyone needs the chrome ring and lens intact for neutral - the green one, I'll send it to them free.
It's probably lightly glued in but when I pressed it back in it went in tightly
although it came out easier than the first time.
Hope that helps someone.
Bull
I know I posted quite some time ago about this....
A good heat gun works great!! Keep it moving on the BACK side and eventually the chrome ring and lens will pop loose on the front. If you have to do any prying, use PLASTIC tools!!
Another helpful tool is a portable heat torch, but BE CAREFUL, although it may work faster, the plastic WILL MELT!!
