how many gears
probike Jul 8, 2019
  1. probike
    probike New Member
    11
    What years have 5 and 6 speed grar boxes of the zl900 and zl1000s
    396
    :hello: Both the ZL 9 & 10 have a 6 speed (all years) tranny.
  3. probike
    probike New Member
    11
    Thanks for the Reply i have other questions
    It says use dot 4 brake fluid can i use an mix dot 3
    For some resone my zl900 Only has 5 gears
    Now heres the big one i always turn the bike off to the left and than lock the forks by going furter to the left .few Days ago i noitched it löcks if you go all the way to the right but it totally drained the battery
  4. 87kawzl
    148
    1 down 5 up, you starting in second gear?
  5. probike
    probike New Member
    11
    One down but seems like im only getting 4 up will check again when rain stops
    396
    :hello: I've never mixed the dot 3 and 4. When the key is all the way to the right that is called parking and your tail light is always on. If your only finding 5 gears then your motor is from a Ninja.
    ZipRoar likes this.
  7. probike
    probike New Member
    11
    Thanks
    396
    :hello: You are welcome. I'm blad to help. :notworthy:.
