ARCHIVE_Tyson
How Do You Get At The Starter Clutch????
'87 ZL600:
Well, the starter clutch has been grinding for a year now. It's finally to the point where it won't turn the engine over, just spins and makes an awful racket. It's my daily rider, so it's hard for me to take it out of commission for a big fix.
Starter bench tests fine. Look in the hole for the starter, teeth on that gear look o.k. Look in the hole from the clutch side, can't see what's going on. One gear has VERY short teeth....
So how 'bout it? How do I get at the starter clutch? Please tell me I don't have to pull the engine. If you do, let me know where I can get aftermarket air filters for each carb. I'm sick of the 20 yr. old hard rubber boots and pointless airbox.
Thanks,
Tyson
'87 ZL600:
Thanks,
Tyson
