ARCHIVE_Wuputt
I thought it was a miracle!
I couldn't believe it, my Eli finally figured out how to make its own gas! I took her for a nice little ride to run out the winter fuel, then stopped to fill er up. Shortly after leaving the station I started getting fuel in the crotch ya know? I was not real surprised cause my cap seal was weak last year and I would get a little overflow when i filled her up too high then romped on it. I putt on home (still pumpin fuel out the cap), get er in the garage and pull the cap, soaked up the mes and started waxing her. All of a sudden the gas starts again! I was tryin to figure out how I could put a switch on it cause that would be a dream come true, the ever full gas tank on an Eliminator! Then reality hit, I noticed a cream colored "baloon" inside the tank. Here someone did a **** job of creaming or sealing the tank in the past and when it started to release from the inside of the tank it got some air behind it. Well after sitting in the shop for a bit the heat from the engine got that air expanding and pushing the gas out(and my hopes up).
Now I got a mess on my hands, I know you guys have creamed your tanks. Where do I get it and how do you get the old lining out?
Putt
Putt
