New lithium batteries
Jonathan Jan 8, 2020
  1. Jonathan
    Jonathan Member
    30
    Does anybody have any experience with the newer lithium batteries in a ZL900? Will the electrical system support the battery or are there any changes necessary?
  2. Harriminator
    949
    212
    Member Supereli changed to this type in his ZL1000:
    Size is different to orig.:
    12N14-3A = 134 x 89 x 166 mm
    LTX14-BS = 150 x 87 x 143 mm
    ...so you may fill the gap w/ styrofoam etc.
    No probs till now, even no extra charging.
    Recommended...:laughing7:
  3. Jonathan
    Jonathan Member
    30
    I’ve read several articles of other older bikes that need to have their reg/rec updated in order to support the use of a lithium ion battery.
    509
    :hello: A few members are now using lithium batteries. I have one in my Yamaha sport quad going on 5 years now. I haven't had any issues. I was told that if one drops below 6 VDC that the charger will not recover it. Then the bike needs to be push started or jumped. You also need to buy/use a lithium charger.
  5. Harriminator
    949
    212
    That was before they had a built-in balancer...meanwhile this is standard! (Check infos by manufacturer).
  6. Jonathan
    Jonathan Member
    30
    yeah I’ve done quite a bit of research on the lithium batteries but I just wasn’t sure if the ‘86 zl900 in specific was set up to accept them without changes. Sounds like it is.
  7. 87kawzl
    224
    Overpriced for the application IMHO, Unless you have a cafe that needs a tiny battery or some other reason to shave lbs. An AGM will give years of trouble free service at a fraction of the cost.
    prfixer likes this.
    509
    :hello: A good qualiy lithium battery does cost twice as much as a standard battery.
  9. Harriminator
    949
    212
    :hello:Lithium batts have a lack: when it's too cold they go down in volts and fail...and can get damaged irrecoverable; finally it's a Q of faith like w/ electric vehicles - as long as there's enough oil no need for a change.
  10. Jonathan
    Jonathan Member
    30
    this is my exact reason. My build is hardly recognizable as an eliminator. I’d share a pic of where I’m at with my build but I can’t figure out how to post pics from my photo stream here.
  11. 87kawzl
    224
    Download pic to your phone then hit the "upload a file" button and pull the pic from your download folder.
    You will be fine with the lion battery. Can't wait to see some pictures!
  12. Harriminator
    949
    212
    1. Click on 'Upload a File'
    2. Choose your folder & the file you wanna upload from your pc or smartphone
    3. Click on 'Full Image' - voila!
    (better twice than none, 87...:D)
  13. Jonathan
    Jonathan Member
    30
    JohnH#II and R. J. like this.
  14. Jonathan
    Jonathan Member
    30
    Still a long ways to go and then complete strip down for powder coating but it’s coming along.
  15. Jonathan
    Jonathan Member
    30
    I know that this is not a purist pleasing picture but please understand that this bike was in absolute disrepair and the rear frame section was rusted horribly. It was also on its way to the scrap yard.
  16. 87kawzl
    224
    It's yours, You do what you want!
    Looking good, is that a 454 tank? Flows with the bike nicely. Purists realize quickly how much a full restoration costs and know there is a line drawn on the ones worth bringing back to stock or ones worth modifying.
  17. Jonathan
    Jonathan Member
    30
    Thank you!
    good eye. It sure is a 454 tank.
  18. 87kawzl
    224
    Snap a top view of that tank from the riders perspective please.
    You should start a build thread to document what you've done.
  19. Jonathan
    Jonathan Member
    30
    I literally have 304 pictures in my build album so far. It’s quite overwhelming when I think about documenting it all into a build thread but I will take it on. I’m sure someone will find something useful.
    I’ll get the exact angle you’re looking for when I get home from work in a couple hours.
  20. Jonathan
    Jonathan Member
    30
