New Tools
R. J. Jul 26, 2015
    594
    :hello: Tools that aren't used much but are well worth it when needed. :thumbsup: Compression Tester & Blind bearing puller. Puller range is 8 MM to 58 MM.
    594
  3. markus56
    3,429
    205
    Nice additions to the collection R.J. :thumbsup:
  4. RLTherio
    RLTherio Well-Known Member
    323
    27
    Nice toys, err tools you have acquired there. I bought me an OTC compression tester kit and once the 12mm adapter stayed in the spark plug hole when I unscrewed the tester. Just had to go back in with the hose and tighten it more. I would rather see a 12" flex 12mm hose that connects right to the gauge instead.
  5. WillyD
    WillyD Senior Member
    3,313
    91
    NICE!!:thumbsup:
    594
    :hello: My son's Jonathan & Jared bought me a new Porter Cable drill press for fathers day & I'm just now getting around to putting it together. It came with a cross hair laser & shop light.
  7. samuelc
    samuelc Active Member
    492
    Im looking at compression testers. that looks like a nice set. I too worry about getting the adaptor stuck in the spark plug well.
  8. RLTherio
    323
    27
    I've had the adapter stuck in the plug well just once, went back in and tightened it up a bit more. Maybe use a drop of blue lock-tite might help? But you would have to let it set up before using and leave it that way for future use.
    594
    :hello: The compression tester I bought is made in the USA so it should be a good unit. It cost $65.
  10. RLTherio
    323
    27
    There should be a hose/connector that is the correct size; 12mm, so you don't have to use the adapter to go from 14mm down to 12mm and possibly have to retrieve it from the plug well.
  11. samuelc
    492
    Im gonna go look at a craftsman set on my lunch break. 63$
    594
    :hello: I bought a bearing puller for when bearings get stuck on water pump shafts. A collection of flywheel pullers, brake caliber piston tool & brake bleeder set.
    594
    :hello: For the most part I do not buy Craftsman tools to much any more since they are going mostly to China Manufacturing.
  14. samuelc
    492
    If its made in any place but USA i aint gonna buy it.:laughing7:
  15. RLTherio
    323
    27
    So what does that leave for "Made in the USA"? Snap-On?
  16. samuelc
    492
    You are right. Craftsman, made in taiwan.
    594
    :hello: It is hard to find U S made tools unless you pay out the ying yang for them. 90% of my tools was from when I worked in Areospace. They all came home with me when I got laid off. :laughing7:
  18. samuelc
    492
    I have a nice American made compression tester but I don't have the 12mm plug adaptor. I can't find anywhere to buy the adaptor without buying a whole set.
  19. RLTherio
    323
    27
  20. markus56
    3,429
    205
    I'm with you R.J., Craftsman lost my business when they decided to go to China and make their stuff. If I'd've known they would eventually sell us out like that, I'd've been buying Snapon years ago!
