Oil change
LT132 Feb 3, 2018
  1. LT132
    LT132 Member
    15
    is the 3.7l amount of oil on the crank case a hard and fast rule?
  2. prfixer
    1,360
    39
    No. It probably won't take that much. The same crankcases were used on bikes that had oil coolers. Do you know about the 2nd drain plug? there is another drain plug towards the front of the motor that will get a little extra oil out.
  3. markus56
    3,243
    148
    Prfixer is right, Zl's have a more shallow oil pan and takes less than that. Put three quarts in and check it after you run it for a minute or so and bring the level up to the top of the window after you shut it down and it settles.
  4. LT132
    LT132 Member
    15
    Thanks guys, after worrying that I over-filled my bike, I realized I had another quart of oil in the gallon I bought.
  5. LT132
    LT132 Member
    15
    Rookie mistake.
  6. prfixer
    1,360
    39
    Do you know the procedure for checking the sight glass? Down on your knees on the left side of the bike while you try to balance the bike as close to upright as possible without it falling over the other way? Set the oil level towards the top of the sight glass. Over-filling can be as detrimental as under-filling.
    markus56 likes this.
  7. LT132
    LT132 Member
    15
    Yup. Thanks. Should the oil level be in the middle of the glass or at the to mark?
  8. prfixer
    1,360
    39
    I've always done mine to the top side of the glass to where just a partial moon part of the glass is empty.
  9. markus56
    3,243
    148
    That's what I do too.....seems to be the consensis on the big ZLs.
  10. LT132
    LT132 Member
    15
    Copy that. Time to let a little oil out
    7,900
    305
    :hello: It always scares me to let the bike hang out at the edge of falling over. :laughing7:. I tie a rope to the handlebars & the other end to my shelves which are bolted to the wall. :laughing7:.
  12. ZLrider
    ZLrider Well-Known Member
    583
    14
    53
    X2, I HATE checking the oil that way as well. Honestly it doesn't hardly seem like a sane person can check the oil without help.
  13. BearHunter
    BearHunter Member
    44
    Always check oïl when the engine is hot. Shut the engine, place it on side stand. Then put the bike in the most upright position you can get. You'll hear oïl flowing down the engine and going back to the crankcase. Then check level.
    When engine very cold, oïl won't flow as easily down.
    7,900
    305
    :hello: I mostly check the oil with a cold motor. Also I thought if the motor is cold most of the oil is already down in the crank case.
    kawboy likes this.
