Pingel petcock
caddie21 May 23, 2020
  1. caddie21
    caddie21 Active Member
    40
    43
    thinking of installing a pingel petcock I like the idea of having an off setting but the question is what to do with the vacuum line going to the original petcock? I guessing just remove it and plug the hole in the carburetor. Anyone have idea what size vacuum lines are?
  2. Harriminator
    1,052
    255
  3. caddie21
    40
    43
    Ok that was what I was thinking. I guess that line only operates the petcock and is not needed.
  4. Harriminator
    1,052
    255
    Yep, to suck the diaphragm for opening fuel channel inside.
  5. caddie21
    40
    43
    Thank you appreciate the knowledge
  6. wayne davie
    wayne davie Member
    7
    I fitted one to my 1000 and tap catches the lip of tank so will have to grind a bit of the tap lever.
    630
    :hello: The ZL STORE sells PINGEL fuel valves but the owner is MIA. If anything you can get the part #s from his Web Site. You will also need the plate. Also you will need to cut the fuel valve slot in your fuel tank to make it larger in order to get the adapter plate on/in your fuel tank.
