Progressive fork springs installation. Spacer?
BearHunter Apr 24, 2018
  1. BearHunter
    BearHunter Member
    44
    I got a set of Progressive fork springs from fellow member Kawboy.
    Do I need to put a spacer on top of them when installing? They seem short compared to the stock one but I have no real comparison since I did not remove the old one's yet.
  2. furchin
    2,054
    39
    7,749
    285
    :hello: They should of come with plastic 2" spacers. I didn't like the plastic ones so I cut 2 2 1/4" spaces from gray 1" O. D. medal conduit pipe. It takes hulk like strength :laughing7: to get the forks caps back in along with the retainer clips.
    BearHunter likes this.
  4. markus56
    3,197
    I've always used the 1" PVC pipe that they come with and cut 2" spacers out of it and used that. Never had a problem and I figured 2" was enough with out making them too stiff. You can effect damping with different weight oil in the forks.
  5. BearHunter
    BearHunter Member
    44
    Thank you guys!
  6. BearHunter
    BearHunter Member
    44
    Does a 1 inches hardwood dowel can do the work?
    7,749
    285
    :hello: Woods to soft. The springs are under a lot of pressure & the fork oil will soften up the wood. I don't recommend it.
  8. BearHunter
    BearHunter Member
    44
    I installed them this morning with 2 inches spacers. Did a little road test. WOW!
    7,749
    285
    :hello: Rides totally different now doesn't it. :notworthy:. So what did you in up using for spacers. Have you ever changed your forks oil.
  10. BearHunter
    BearHunter Member
    44
    Ho yes the ride is totally different! I used pcv pipe and put à washer between the spacer and the spring. Forks oil change was one of the first maintenance I did last winter. And as we say here, it was not a luxury. I put Bel-Ray 20w in them.
  11. BearHunter
    BearHunter Member
    44
    Ho yes the ride is totally different! Totally new bike that now behave on the road accordingly to his agressive look!
    I used 1" outside diameter pcv pipe used by electricians that I cut in 2" lenght. I also put a 1" washer between the spacer and the spring.
    Forks oil change was one of the first maintenance I did last winter so it was already new. And as we say here, it was not a luxury, oïl was pitch black. I put Bel-Ray 20w in them.
  12. rammy1500
    rammy1500 Supporting Member
    926
    113
    Is there a way to check the fork oil level once you put it all back together and on the bike?
    7,749
    285
    :hello: No. With springs out & fork fully compressed you measure 6 11/16 inches (170 mm) to the placement of the air cap. I use a 1/4 dowel rod & a gun bore light. It's easier just to do it by volume. IMG_6153.JPG IMG_6154.JPG
  14. markus56
    3,197
    I've never checked the level with forks installed on the bike. I don't see how it could be very accurate that way. Always measured with springs out and forks compressed as shown in the manual.
  15. 87kawzl
    87kawzl Senior Member
    1,362
    86
    Rammy, you could get away with changing the oil while on the bike and use the 235ml amount specified in the manual. That is probably the closest you can get without dropping the tubes.
    7,749
    285
    :hello: Yes. The said procedure per manual is mostly for when new fork seals are needed. They have a dry measured amount & one for when just changing the fluid by removing the phillips screws on the bottom of each outer fork tube. Make sure to release any air first. To get even more oil out you can use a shot gun cleaning rod but first remove the springs.
  17. GaryD
    GaryD Active Member
    291
    16
    Are these springs still available? they don't show on their website.:(
  18. R. J.
    7,749
    285
    :hello: They are discontinued. Once in a while they show up on E-bay.
