ARCHIVE_Firecracker
Starter Button Corrosion
Has anyone else had a problem with their starter button working intermittently, or not at all? A couple of years ago I had this problem, and the solution was simple:
take apart the housing that contains the starter button, carefully remove the starter button and expose the contact plates. One of the little plates on my bike had so much corrosion on it that they weren't making good contact. We just took a small round file and carefully cleaned off the corrosion, reassembled the parts, and it's worked fine since.
