reserve lighting device ???
  • Thread starter Thread starter ARCHIVE_jaydog
ARCHIVE_jaydog
TOO MUCH $
I'm selling a ZL 900 now as well.$3200 is very high.Not that it isn't worth it,but kelly blue book shows a little under $2000.Im looking for $2500 -$2300 for mine.17900 miles,valves and carbs just been cleand and adjusted by a professional,.Bike is in very good shape with no dents and extra parts.Good Luck!
Hey Jay, Where You At, Might Be Intrested If Your Close and Can Pick it Up, Later Rocky :twisted:
Here's what the GPZ book says:
The US and Canadian models contain a relay in the headlight circuit. In these models, the headlight does not go on when the ignition switch is first turned on, but the headlight goes on once the starter button is pushed to start the engine, and stays on until the ignition switch is turned off. But the headlight goes out whenever the starter button is pushed to restart the engine after engine stalling.
*If all wirings and components other than the reserve lighting device check out goo, the device is defective.
Hope that helps. Later.
