Sirius Consolidated Inc - carb kits
Jarney
Strip Warrior
Staff member
Administrator
Super Moderator
USA IN, East Central
Hey guys,
Just thought I would mention this. I did a search on the site and didn't get any results on this name so I don't think they've been mentioned before. I was in need of some carb kits and Georgefix didn't have what I needed so rather than wait I found this place. Sirius Consolidated Inc - in Ontario, Canada - see link below for their home page. They had what I needed and it took 6 days to get to Indiana, USA. Price with shipping was $74.50 for 4 carb kits. They are more pricey, but if you are in need and don't want to wait, they may be worth a look. Later.
http://www.siriusconinc.com/default.asp
"Keyster Carb Kits K-604" How do they get by selling one kit to fit all those bikes? Did you have to specify zl1000? I know as well as you that the zl900 bowls are smaller than the zl1000 bowls!
Website is painfully slow to load,, brings back bad memories!
You open their home page, select Kawasaki, type in Eliminator in the second box, then click on carb repair kits in the next one. That will bring up a page for the Eliminators. I don't know how they are using the same part number for all of them. I just know that everything in the kits I got fit fine. I did notice that the bowl gaskets seemed a little small as far as diameter - I thought they fit fine - didn't have to stretch them or anything to get them into the bowl channel - but they seem to be working fine - so far, they have only been installed for a day or two - I mainly just wanted the needle valves. Yeah, website is slow too. It's just an option - the other kits may not be the right ones? I had a new set of gaskets from Georgfix - I should have compared them - if I remember, I'll either compare the two the next time I pull the carbs or I'll take George's and see how they fit in a set of bowls. Later.
Bowls are the same! I just measured em.
Good to know Wuputt. So more than likely the 600 and 250 bowls are the same too since the site has them all listed with the same part #? Thanks. Later.
