Soft Clutch 5/6th gear ZL900
bigdavet Jun 17, 2018
  1. bigdavet
    bigdavet New Member
    I have a question about my 85 ZL900, it has to do with the clutch. When I shift into fifth gear, it feels a little soft, like I have to pull the lever an inch or so before the clutch releases. Same with sixth. Up- or down-shifting. All the other gears are fine. Weak clutch retainer springs, perhaps? I would think that you would feel it through all the gears if that were the case. I don't feel any slipping or anything else unusual, except for the length of the lever pull. Thoughts? (Bone stock '85, 25K miles, runs great)
  2. markus56
    3,209
    Pull your clutch basket and look at your leaf spring to see if it's missing any fingers. The fix is to use the updated springs (2) and nut from the later Connie's (2006).
    bigdavet likes this.
