Stuck Hub Nut
Dylan Apr 23, 2018
  1. Dylan
    Dylan New Member
    Hi All.
    So I have been working on swapping my starter clutch on my 87 ZL600 and I cant seem to get the hub nut off.
    have it held with some holding pliers and have a 36mm socket on it.
    Noticed it looks a bit bent out of shape. Any advice for a fairly new home mechanic?
  2. Harriminator
    736
    119
    Actually I use a clutch basket holder for this job: tmp_11079-s-l400(4)-1860399138.jpg
    It's a 'safety nut', you'll need a new one...
  3. markus56
    3,197
    Use a 1/2" drive impact driver and it'll come right off. It's made that way so as to not come off during operation. You need to update the clutch finger washers and use the updated nut.
    7,749
    285
    :hello: It's called a crimp nut. Like said before it is a one time use. Up grade to the ZG 1000 nut & 2 star sprung spring washers. I did this on my ZL 10.
  5. furchin
    2,054
    39
    R.J., He has a 600, not sure if the parts are the same.
  6. MAIK72
    MAIK72 Well-Known Member
    148
    old part with this nut and one spring is discontinued. You will only find the black nut (with shorter thread) and 2 springs. Use an impact gun to remove it and get some help to torque it to specs
    7,749
    285
    :hello: OH. OK: The one from the newer ZX 600 may work.
  8. MAIK72
    148
  9. markus56
    3,197
    So the ZL600 uses the updated nut and 2 spring washers like the bigger ZL's?
  10. MAIK72
    148
    7,749
    285
    :hello:Nice. :notworthy:. What happened to my auto translator. :laughing7:.
  12. Harriminator
    736
    119
    :hello:Which translator? Easy to read...:laughing7::D
    7,749
    285
    :hello: So what does it say. :laughing7:.
  14. Harriminator
    736
    119
    :hello:Blablabla...old nut, new nut...blablabla...old leaf spring, new leaf spring...blablabla...new leaf spring on old nut not good...blablabla...already explained by R. J. on this site a long time ago..blablabla.:laughing7:
  15. R. J.
    7,749
    285
    :hello: I do remember documenting the clutch hub nut & duel spring connie up grade but can't find it. :banghead:.
  16. 87kawzl
    87kawzl Senior Member
    1,362
    86
    Did you search "RJ fixed busted nut"....nevermind it just brings up Daytona....hehehehe
  17. Dylan
    Dylan New Member
    So since the nut has been update do I need to also get the 39130-1071 leaf spring as well?
    And if so then do I need to order 2 since it is in 2 pieces or do they come together?
  18. Harriminator
    736
    119
    MAIK72 likes this.
  19. MAIK72
    148
    :hello:nice.When I made the upgrade 4 years ago it was the only information I could find about this nut-case:D
  20. RLTherio
    RLTherio Well-Known Member
    313
    22
