SUCCESS
  • Thread starter Thread starter ARCHIVE_SnakeDoctor
ARCHIVE_SnakeDoctor
Still need that head
I finally got the 900 Eliminator to the house with the papers and I'm stoked. :D I do have one real problem and that's the head for it. It shows only 22900 k on the clock and by the looks of the rest of the bike, this should be right on. It's been sitting for the last 5 years without the head but indoors. I'm in Thailand so shipping is a problem. I would also be interested in a full gasket set and a set of oversized rings if any of you guys can direct me. Thanks for any help. SnakeDoctor
gasket set
Thanks Brian, I'll look around a little bit more and maybe I can get a better deal. If all else fails I'll drop you a line and maybe work something out. Snake
Thanks but got the head
Head will be on its way soon. Thanks
:D M.HANGER,
LOOKIN' AT YOUR PICS DO YOU INTEND TO USE THE DRAG BARS THAT ARE FITTED OR CHANGE THEM?
THE REASON WHY I ASK, I USED NARROW Z BARS ON THE TRIKE AT FIRST BUT FOUND OUT IT WAS HARD WORK ARM PUMP, WRIST ACHE AND KNACKERING ON A LONG RIDE.
JUST A THOUGHT
RUFF :bom:
THE BARS THAT ARE ON ARE FOR MOCK UP I WAS INTENDING TO USE 32" DRAG BARS IF I CAN STOP THEM HITTING THE TANK???SO EXACTLY HOW MUCH LIKE HARD WORK ARE THEY? :detective:
:D THE MISSUS AND I RODE BACK FROM THE BULLDOG BASH FULLY LOADED, RIDIN' FAIRLY HARD BY THE TIME WE'D PASSED KIDDIMINSTER ON THE WAY TO BRIDGENORTH I REALLY HAD TO STOP, FINDIN' IT HARD TO HANDLE ON THE CORNERS.
AFTER A BREW WE CRACKED ON HOME.
IT WAS ONLY A THOUGHT ABOUT WHAT BARS YOU INTENDED TO USE. AT THE MOMENT I'VE GOT SOME SORT OF HIGHWAY BARS ON THAT I PINCHED OF THE WIFES BIKE, THEY SEEM TO DO THE TRICK WITHOUT THE GRIEF.
RUFF
I WAS AT ONE POINT GOING TO FIT CLIP ON BARS BUT THOUGHT THE STRETCH A BIT TOO MUCH.JUST LOOKING AT YOUR GALLERY PICS(very nice work) CAN`T SEE WHERE YOU HID HAND BRAKE LEVER ,I`M STRUGGLING TO HIDE IT .ANY IDEA`S??? ANDY :cool10:
:D WE'VE USED THE LEVER OFF THE RELIANT, WE FITTED IT TO THE BOTTOM A FRAME JUST BEHIND MY RIGHT LEG. LOOK ON MY GALLERY ( TRIKE 5 ) YOU CAN SEE THE MOUNTING LUGS FOR THE SAID HANDBRAKE.
RUFF
