Hi all.
I Know I havent posted on this board much but I have a few questions I'm asking myself while reading the ZL1000 supplement and the base manual (gpz900/zx900a). Was just wandering if any of you guys could help.
Most of us probably know that the Zl1000, Gpz/ZX900, Gpz1000rx,and concours Crankshaft, Conrods and Crank cases are the same. the main bearings are the same.
However, the conrod big end bearings are different Hmmm.
Eg ZL1000 big end bearings - Brown = 1.470 -1.475m/m Black = 1.475 - 1.480m/m Blue = 1.480 - 1.485m/m
The ZX/Gpz900 big end bearings are as follows - Brown = 1.475 - 1.480m/m Thats is the same as the Black ZL bearings. The Gpz/zx Black = 1.480 - 1.485m/m which is the same as the Blue ZL bearings. The ZX/Gpz Blue = 1.485 - 1.490m/m which is off the Zl scale.
The difference here is because of Con rod big end bearing insert - Crankpin clearance. On the Gpz/ZX900 being tighter 0.036m/m - 0.066m/m the ZL1000 is 0.046m/m - 0.067m/m.
Is this because the Gpz/ZX900 engine is built to rev higher? I am about to rebuild my engine with Wiseco pistons Gpz/ZX900 cylinderhead and Camshafts, A dynojet stage 3 with pods and modified exhaust.
Would building my crankshaft using the Gpz/ZX900 clearances work better for my engine?
If I cant figure this out I will just rebuild my crank to the ZL spec to be safe.
Anyway, Thanks in advance for any input.
Motorsiklemad1
