Zl 1000 junction box
June Jul 20, 2018
  1. June
    June New Member
    7
    Any ideas where i can get a replacement or mine fixed im located near cardiff south wales uk
  2. Trojan441
    Trojan441 Active Member
    289
    10
    Which part are you talking about? The ignition controller?
  3. June
    June New Member
    7
    Its the black box down on right side of bike that holds all the fuses
  4. Harriminator
    736
    119
    Aka fuse box; can be repaired simply if it looks inside like this: tmp_10699-IMG_20180520_122256744589556.jpg
    Print relais can be ordered so either give it to an electronic shop or you know someone who's good in soldering.
  5. markus56
    3,197
    We have a member that rebuilds them. He's in the States so you'd need to ship it.
  6. June
    June New Member
    7
    Had all soldering renewed theres signs of wear/carosion on the green side the soldering is, everything worked for few minutes until head light was switched on the it all went off again checked all fuses they seem to be all ok
  7. June
    June New Member
    7
    Oh right ok will have to think about it would there be anyine in the uk that possibly fix them
  8. Trojan441
    289
    10
    Check all the wiring too and make sure the "Earths" are well grounded and your battery is fully charged!
  9. June
    June New Member
    7
    Ok will go through it all thankyou for the replies hopefully will get it sorted soon
  10. Trojan441
    289
    10
    Sorted?
