Zl1000 valve adjustment
ajdre Feb 28, 2013
  1. ajdre
    ajdre Member
    Does anyone out there know what the valve adjustment procedure is for the 1987 zL1000?
  2. zl_havoc
    zl_havoc Well-Known Member
    148
    53
    There is a download section with all the manuals for all our bikes. Just scroll down on the main page to download section, pick the right manual and you should be able to find what you need.:thumbsup:
  3. ajdre
    ajdre Member
    Thank you!
  4. Jarney
    4,475
    16
  5. ajdre
    ajdre Member
    Does anyone know what the actual valve clearances with feeler gauge for the 1987 zL1000?
    Thank you,
  6. Scoobys_piece
    2,026
    Valve Clearance Intake .13-.18
    Valve Clearance Exhaust .18-.23
    Go through them, then go back and go through them again. You'll notice differences from first go around.
    Took 3 hours for me...but that's just me. The thread Jarney offered is INVALUABLE!
  7. kenneth
    kenneth New Member
    13
    is it in inc or mm..
  8. 87kawzl
    185
    Check the manual, usually it's .0xx if inches.
  9. Trojan441
    560
    45
    On the small 4's this measurement is in Metric mm's and is the 0.13/0.18 Inlet/Exhaust respectively are the tightest/ smallest gaps allowed equalling 5.1 thou'/7.08 Imperial Thou'@ respectively. The engine has to be stone cold the books recommend leaving the engine to cool overnight. https://www.convertunits.com/from/mm/to/thou
