ZL400 Frame/chassis question
Tom obrien Jun 15, 2019
  1. Tom obrien
    Tom obrien New Member
    Hi i have a zl400 1995 but on closer inspection i have noticed the frame number has ZL600 in the VIN would this once have been a 600cc or did they use 600 frames for 400cc bikes it is registered as a 398cc
  2. Trojan441
    560
    45
    Are you in the UK? This sometimes happens because the ZL400 was never officially important here, I will dig out my Log Book to see what it says on mine I know @ MOT Test Stations the ZL 400 regularly come up as ZL 600 on the data information! As far as I know the frames are identical, but then I only know about the ZL "A" series!
  3. Trojan441
    560
    45
    I think if the ZL 600 is on the VIN plate you may have a ZL 600 bike, check your engine number against also the information on your documents, You could have a ZL 600 that has had an engine swap!
    My ZL 400 A Log Book says ZL400A 0040**; Engine number ZL400AE-0039**. Having said that just checked my VIN Number on my ZL600A & it has JKAZL416GA004*** on the Frame & it has ZL600AE0040** on the engine. I hope this helps!
  4. Tom obrien
  5. Tom obrien
    Thanks for the info i may pay the dvla for the history to find out when it was changed...i done this before with a old harley i had and found out when it was imported and who owned it in the usa
  6. Trojan441
    560
    45
    Okay, DVLA are a usually a nightmare to deal with!
