ZL900 - Neutral gear indicator not working
Scrolls5 Mar 18, 2020
  1. Scrolls5
    Scrolls5 New Member
    Hi guys,
    I'm from the Netherlands. I've an ZL900 '85 that was imported from the USA. Recently I've repaired the bike to a perfect healthy engine condition, however the neutral gear indicator light on the headlight is not working. The sensor I checked on the "front bevel gear case" looks ok. Is this a well known issue or something that rarely happens on these beautiful bikes.
    Sincerely,
    Scrolls5
  2. madmanncr500
    5,463
    78
    93
    You can unplug it and put direct power to it and see bulb lights up...might just be a burnt out bulb...good luck.
    87kawzl likes this.
    594
    :hello: Swap the bulbs around it may be burned out as said by MADMAN. Did you remove the switch from the motor to see if it fell apart. I've never had one out so I don't know what it looks like.
  4. lowlife
    3,487
    26
    Power
    Ground
    Bulb
    Switch
    That about covers it
