Chrispyweld
- Mar 7, 2016
Now that I got it all broken apart all my white trashy instincts are telling me to hack the back off this thing at the shocks and drop a coffin/prism/frisco tank on top of that sexy straight backbone. A turned up bobtail fender, shorter rears shocks, and some chopper paint sample panels sounds about right. But probably not now.
Anyone have any info on the ninja front end of the same era? I see they are dual disc and have "dampeners" which I assume work like Ricor's? Light valves for pressure from below and harder from the top to ease nose dive on breaking and soften the rougher roads. How well do these work? I can grab a set for around $100 and the dual disc alone seems like a reasonable budget upgrade. I would have to change out front wheels to accommodate the dual discs but that should be doable as Cyclepsycho here in town has a warehouse of bikes and parts to pick through.
I also have a chance to get an 86 GPZ motor that has been freshly built with high comp. pistons, polished and ported heads and receipts to prove it. Built for a sand rail but immediately upgraded to a 1000cc motor for drag racing at the dunes in Florence. The only thing holding me back is the chain drive conversion. If I understand I either have to crack the case or swap out the swing arm and rear wheel. Not sure if i'm the reward is worth it. I might get a little more for a bike with receipts for a $1600 rebuild but I can't see it increasing the value that much. Maybe if I decide to keep it I will get it as a back up. The carbs, cam, head, and pistons are probably worth the $400 he's asking.
What he said, try resetting the tensioner.
