ARCHIVE_gehang
Need help reading wireing diagram in ZL1000 manual....
I'm looking at the zl 1000 wiring diagram allough it's all greek to me...
I'm having a serious wiring issue, that I imagine has to do with only 1 wire, but i'm trying to find that one wire...
While riding, obiouslly most noticable at night, I lose most of my electrical. It effects everything except the turn signals.
It will work fine for a few days, then go down for a few hours, some times down for days, but then go days working just fine. Since it effects so many parts I imagine its one of the first power lead wires.
The start button works, and the turn signals work front and back(including hazzard flashers) what does NOT work is (console lights, tachometer, horn, headlight(high or low), breaklights, kickstand safety switch(kill when in gear)....
I bought a fuse kit and replaced all the fuses in the junction box so i'm sure it's not a fuse....
If someone can read a wiring diagram i'll email you a blown up copy if needed. I need help finding out what the turn signals(and hazzard lights) have seperated from everything else. There has to be somewhere down the line where the power spits off for the turn signal, then I can have a good idea on where to search for a wire break/melt at...
Clueless and in need of help,
Gehan G.
Gehan G.
