1st of all, hello! Im a new member to the forum. Ok boys & girls: I have a ZL1000 that the fan quit working on me. I diagnosed it & seemed I had a popped relay. I ordered & replaced both. (Just to be safe) Also, according to the recommendations on here, I jumpered both temp sensor wires. Worked great for a couple days, then fan quit working again while riding, but comes on & goes off after u kill it like its supposed to. Think I may have a bad temp sensor? May have popped another relay? Rad cap has been replaced & looks near new. Tried bleeding the 2 air bleed bolts also & no hissing. One thing I did notice is the oil temp sensor wire-lead is not hooked up. Can't even find the wire. Not sure if sensor went bad, or if it is even worth worrying about? Im thinking of wiring a manual fan switch just in case, but would like to get it working correctly. Any suggestions?
