decals
  • Thread starter Thread starter ARCHIVE_aiolos_112
ARCHIVE_aiolos_112
EL 400
HAIL TO ALL IM TONIS AND IM FROM GREECE,I WANT TO ASK IF I MAKE MY MOTO FROM 400cc TO 600cc HOW MANY HP I WILL TAKE MORE,NOT ALL THE ENGINE BUT THE CYLINDERS AND THE PISTONS ( sorry for my write im not so good to write as to speak ),NOW I MAKE O HP TEST AND I GOT 56HP ON THE WEEL I GET ABOUT 175KM/H. THENKS . RIDE FAST
I have an 86 ZL 600 US Spec. the magazine tests from 4-86 State the 600 has 57.24 at the rear wheel. I have put F1R slip on Exhaust and Shimmed the carb needles and easily hit 120 MPH (200 KPH) I suspect that the 600 has more torque over a wider range than the 400. It would give you more useable power on the street. After all torque is what gets you moving. I also have the factory service manual and it says the 600 has 74 HP and the 500 has 71 HP, but peak numbers have no meaning on the street in the real world. The powerband and how wide and useable it is means more than a high HP at 12000 rpm and no power down low. Hope this helps you, and don't worry about your english. You are way ahead of me, I would not even know where to start if I had to type in greek. Take care and happy motoring on your ZL.
Check out the Dutch Site, www.eliminator.nl There are a Couple of 400 Owners on there, Mabey you can get some More Info. Also Membership is Free and I think theres a Member From Greece Too, Hope this Helps, Later Rocky O'. :twisted:
What do I need to open the download section on decals? I downloaded it but windows says it can't open it.
Thanks,
SD
Did you change the file extentsion to eps if needed as described in the download description? .eps opens with photoshop on my puter
I'm using firefox but the file already says EPS and i can't get to it to do anything with it.
Ok i'm at work, downloaded the file with IE and had to change the file ext to.eps. It opens here with microsoft picture it!
Make sure you have the "hide file extensions for known file types" check box unchecked in start/control panel/folder options. otherwise you are just changing the file name. let me know
I can't get it to open with anything. If you can do a remote somethime and show me what the heck I'm doing wrong, it would be great. I'm not the quickest on this computer bike. :wink: Let me know whenever you have a few minutes and what's the best time to get with you and I'll get back to you.
Thanks,
SD
Sure we can do that, maybe later tonight or later this week. If your taking it to a print shop or whatever just email them the file, they'll know what to do with it.
