I purchased Hot-Jet Ceramic Header and Manifold Coating from http://www.masterseriescoatings.com/index/high-heat/
Here are my thoughts on this product:
1. Buy more than you think you need by about double.
This product has alot of solids in it and it doesn't coat like paint does. It also must be stirred to ensure all the solids are mixed with the liquid. Once you think you have it stirred or shaken, stir or shake it MORE. My first bottle had most of the solids left in the bottom of the bottle. I had to buy a bigger bottle to get a good coat on a set of ZL600 headers.
2. Make sure the prep of the parts are clean.
Our first spray of this product peeled off the header like it was nothing.
3. The instructions say to buff the finished product with 0000 steel wool.
Do so LIGHTLY. I went through the ceramic coating without even trying
The product needs to be baked for 1 hour at 400 degrees f or it needs to sit for 48 hours before buffing
I had real hope for this product but it seems that it isn't as good as the manufacture thinks it is. It would be wonderful IF it worked like they say it would.
I have no idea what the long term effects might be. I'll keep you posted.
