yep, I got em and that is a link to my store... thanks vinney !
Petetherat-- you can do your window shoppin' on the ebay store and then pm me here and you will get the zl-oa hook a brother up deal pricing, if you prefer to use ebay for whatever reason I will not be able to change the price for you.
vinney is correct you have a problem with the needle valves in your float area, its not likely to be corrected by berrymans, seafoam or any additive, its probably a bit of rust or crud rather than fuel gook residue. you will likely have to pull and clean up your carbs to correct this problem.
there is a "get lucky" fix that might help. turn off the fuel valve and open the drain plug on your float bowls to empty them of fuel. when they are empty close the drain screw and put fuel valve back on prime, you may want to gently tap on the offending carb with the plastic end of a screw driver while it fills. the idea is to wash the crud past the needle. by emptying the bowl the float drops all the way down and opens the needle valve to the max and when the fuel is turned back on the initial rush of fuel may move the bit o' crud out of the needle seat area and restore the seal. If it dont work the first time repeat twice more as needed, if that dont do it ... you aint gettin' lucky..... pull the carbs and clean em up.
would be a good idea to pull and check your fuel valve as well, most of the stock fuel valves have a deformed filter screen that does not seal properly allowing these kind of things to get into your carbs... this is why most guys who have changed to pingle fuel valves have done so
good luck... hope ya get lucky... I have a few times !
