Hey! I have just got my first bike back. My brother borrowed it for a while and then my son had it for a bit. He put whatever in the gas to keep it from going bad last fall but didn't run the gas out of the carbs. It would start up for a second, maybe two and then die. I figured it must be the carbs gunked up so I took them off of the bike and cleaned em up with carb cleaner. It ran 15-20 seconds and then would die. If i wait for a minute or more it will keep doing that, try to start it right away and it runs for a second or so. I have the carbs back off of the bike and am trying to do a more thorough job this time. I have the floats off ( which don't seem to all be adjusted the same) but see no way to take out the jets under them.
The only change from stock that I am aware of, and I bought the bike new in "85", is a small valve between the petcock and carbs to turn the gas on and off. I guess the petcock went bad and that was the fix....... Would like to get a petcock to go along with fixing the carbs if anyone knows a place to get them. Anyways, back to original question, do I need to get that jet out and if so, how to do it without breaking something. This is a zl900A1. I have been reading a lot of the posts on here and see that there are quite a few very knowledgeable people and I appreciate any help. I don't mind getting grease under my nails but mostly have to figure things out as I go.
