Breeze
Well-Known Member
Thanks, thats a good suggestion. After about 20 mins. of fumbling with it, I was able to somehow get my big hands in there and get the bolt started just enough to then hit it with a ratchet from underneath. Now I have to pour a little coolant in and make sure the water pump gasket stayed in place when I was installing the cover. I used a little sealant on it to help keep in place, but still don't know for sure if it did or not.
I found it best to put the O-ring on the end of the coolant pipe with a dap of dielectric grease then slide it up into the water pump. I've done quite a bit more spark plug cap rebuilding since the begaining of this thread. The biggest problem that I run into is the resistors stay springs being corroded. So I started cleaning the intire spring on my buffers wire wheel. I bought my buffer from Harbor Freight. $80. I've had it for 5 years.
