dale,
assuming stock bikes, and a "perfect" run, what would you predict as the 1/4 times for both the zl900 and the zl1000 ???
DW: I ran a 11.20 on a ZL 900 bone stock, i never ran the 1000, but they are very close really, though the 1000 makes more mid range. This really does not help the ET.
assuming "perfect" tuning what would you expect these two bikes to dyno out at in terms of absolute peak HP??
DW: Take a look at my dyno charts on the ZL-1000 with my slip-ons, then you can figure this out pretty easy.
in earlier posts you've recomended the use of rotella-t, I belive 5w-40, I have used this and found it to be an excellent choice.. thanks!!
I was wondering what you belive the benifits of this oil over the competition is technically speaking.
DW:
Its cheaper .... Ha , the oil issue will go on until the end of time and i really dont want to go there. This is very good oil and a good value. I also use The X1-R product, again please take a look at my web site.
Is there any chance that it would be possible for your exhaust systems to be produced in a way that more closely resembles the factory cans???
DW:
No, the bikes are way to old and it cost way to much to produce a new design, I have wanted to discontinue these a few times, but i have yet to in fact. But if sales drop off more this summer they may be gone after that.
I have a friend who is a member here, his bike turns over fine with one spark plug removed, but will not when all are in place. He has removed, torn down and re-assembled this motor more than once and is not finding the problem, I know this is limited info, but could you make some suggestions on what may be the cause of this problem??
DW:
If the motor is free and the cam timing is set properly as well as valve lash, and it has good compression, it may be flooded with fuel causing cylinder lock, or if it does not turn over with the carbs removed it has to be electrical.
This means low battery, bad connection or solenoid or week starter
Be careful if it gets flooded with fuel it can bend a connecting rod trying to turn over it if back fires.
also wondering about main jet suggestions for zl9 with k&n, stock pipes. and additionally same bike with pods and performance exhaust.
Stock main jets with my jet kit and included timing advancer, i dont like to give out my settings or i dont have a kit.
thanks !!
