Hey Kiwi, Pretty Sure the Concours Cams Will Fit[The Top end of the ZL 1000 is From the Concours]May be Slightly Different from the ZL's, Check the Kawasaki Website For Part# and Then Call Your Kaw Dealer, They Should be able to tell You if the Parts Match. Theres also a Company in the US that Makes Replacement Valves, Springs and Tensioners, Dont know about the Cams, Will see if I can Find there Adress and Post Back, Later Rocky
Hey y'all check out the alumaloy website - if you are interested was thinking we could share an order - 2 1/2 lbs would be plenty to pass around to all - pieced out like a welding rod - we all have a bunch of aluminum between our legs could use some repair once in awhile.
My wife says I don't play well with others but what does she know being a split tail and all - don't want to order the 2 1/2 lb package unless we have enough that want some so get back to me.
I'm interested. Kinda pricey stuff, but the split order idea makes sense, especially if it sucks then no one is stuck with two pounds of crap. When you thinking of ordering Bull?
Later,
SS
