CARB CLEANING SERVICE ,ultrasonic cleaning
Just putting in my two cents......... He's an absolute pleasure to work with and is second to none in expertise and workmanship!!!!! I've had him do three sets for me since spring with three more to come in the very near future. He is the ZL carb Guru for sure but I just put on a set he did for a GS750 and they too have performed as well or better than a brand new set. No one will ever touch another set of carbs for me as long as He'll do them for me. He Is The Man!!!!!............ THANK YOU MARK ......THOSE ARE VERY KIND WORDS .................RICK
Ditto! He cleaned mine and they look great and run like new! Thanks Rick!
Hey there Rick am interested in getting my ZL1000 carbs done but would probably be over winter also was wondering if you would install an upgrade kit when putting them back together, was looking at the stage 1 kits as I really dont need this thing much hairier then it is but would like a little crisper throttle response. Also approximately what is your turn around time?
Thanks for your time! Terry
I have the CRB-K18-3.0 kit. this one is designed for use with pod air filters. the other is designed for use with stock air box.
Do the ZL's not have the same probs other Kawi inline 4's have with pods?
So I would probably get the stage 1 kit then as I want to keep my box, does the K&N filter make that much diff over an aftermarket hi flow filter?
cant say that I have personaly tested this on a dyno. I belive that it is generally accepted that k&n allows for more air flow and helps to produce more power when jetted & tuned properly.
as far as the problems with other kaw. bikes... I dont know.. what problems do other kaws have with this set up???
Ill I know is mine works perfectly with pods, timing advancer, and jet kit.
Re: CARB CLEANING SERVICE ,ultrasonic cleaning UPDATED 4/16
Hey Rick,
I looked at your website and I must say your bikes look so dam nice. You definately take a lot of pride in them. I am hoping my comes out just as nice. I have a question: I have seen on your pics that some parts look like they were made. Did you make the forward controls that were on I believe it was the Honda that looked like a home made bracket on them. I have been looking for forward controls to put on my ZL900 with little luck. Any direction on where to go to get them or have them made for my bike that won't make my banker (the wife) cringe when I approach her about it. Thanks for all your help.
Just had mine done a couple weeks ago and I would have to agree with all of the comments on Rick's work. He does a great job - When I purchased my ZL the carbs were leaky and had been tinkered with before by the previous owner whom had NO clue what he was doing. So I removed them and shipped them out to Rick. I got them back, installed them on the bike and all I had to do was tweak the idle knob to where I wanted it.
Thanks Rick!!
hi Rick, how much for your cheapest service option (the $125 one) for a UK customer? i have a ZL600 with carbs that could do with a bit of an overhaul. Get back to me when you can mate.
Zub.
How do I get in contact with you? I need my carbs cleaned.
Hey Rick,
I've got the ZL900 carbs boxed up and ready to come your way Monday.
Got a question, can you clean and sync any Kawa carb? I have a 1982 KZ1000 set of carbs I JUST pulled off. The bike has a bad low-end miss when it's cold, it cleans up eventually but it has a bad flat spot too after 5k-6k. Can you do these too?
Andy
Rick,
Can you send me your address to send the carbs to have them done.
Thanks in advance,
Joce
As some of you know I have trouble with my carbs and I am glad to hve taken them apart to see how they work.BUT NEXT I WILL DEFINATELY BE SENDING MINE TO WICKEDZL900:laughing7:
WickedZL900, tried to pm you. Says your box is FULL. MikeC
